Posted · "un-original" fans not working
Hi.
I had a crash with the Ultimaker 2, which ruined both the fans. I ordered a set of fans from eBay since the support took so long to reply to my mail.
The fans were 30 x 30 x 10mm 12v 0,08A, the same as the ones that came with the Ultimaker 2:
http://www.ebay.com/itm/221393479086?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Ive tried to connect them, but they dont start (I have made sure the fan speed is at 100%, and testet different speeds).
I have also measured the voltage to be about 19 V, but still no movement.
I dont have any power source that I could test the fans with at the moment.
I also may add that the original fan wires that runs along side the feed tube is absolutely garbage. Thin as a hair.
Have anyone else encountered problems with un-original fans?
