Thank you Daid for a fast answer.
then i must wait for the new relase or use netfabb so long.
Ah, daid ifound the prob....... the path was to long.
I changed the folder directly to F: and it works.
Thank you for bring me on the right way.
Hi Daid,
I have a new Problem with Cura Slide.
Do you know what the Error Mean?
"Something went wrong during slicing"
The Log File:
File F:\Cura Temp\Türkeil.stl is being chain exported.
Carve procedure took 1 second.
Preface procedure took 1 second.
Inset procedure took 13 seconds.
Fill procedure took 59 seconds.
Speed procedure took 1 second.
Raft procedure took 1 second.
Skirt procedure took 0 seconds.
Comb procedure took 0 seconds.
Cool procedure took 1 second.
Dimension procedure took 1 second.
Traceback (most recent call last):
File "app_main.py", line 51, in run_toplevel
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura.py", line 80, in
main()
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura.py", line 72, in main
sliceRun.runSlice(args)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\util\sliceRun.py", line 81, in runSlice
skeinforge_craft.writeOutput(fileName)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_utilities\skeinforge_craft.py", line 135, in writeOutput
return pluginModule.writeOutput(fileName, shouldAnalyze)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 275, in writeOutput
gcodeText = skeinforge_craft.getChainTextFromProcedures(fileName, procedures[: -1], gcodeText)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_utilities\skeinforge_craft.py", line 44, in getChainTextFromProcedures
text = craftModule.getCraftedText(fileName, text)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 96, in getCraftedText
return getCraftedTextFromText(archive.getTextIfEmpty(fileName, text), repository, fileName)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 106, in getCraftedTextFromText
return AlterationSkein().getCraftedGcode(gcodeText, repository, fileName)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 182, in getCraftedGcode
self.addFromUpperLowerFile(repository.nameOfStartFile.value) # Add a start file if it exists.
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 174, in addFromUpperLowerFile
self.distanceFeedRate.addLinesSetAbsoluteDistanceMode(alterationFileLines)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\fabmetheus_utilities\gcodec.py", line 361, in addLinesSetAbsoluteDistanceMode
self.addLine('()' + line)
File "F:\Ultimaker\Cura 12_08\Cura_12.08\Cura\cura_sf\fabmetheus_utilities\gcodec.py", line 330, in addLine
self.output.write(line + '\n')
UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in position 53: ordinal not in range(128)
Where does i find the Unicode?
I think I know where it goes wrong. Could you try removing the {filename} tag from the start code to see if that solves it? I thought I tested that... but looks like it is causing problems with none-acsii chars.
Daid, your a little wizzard. :lol:
That was the problem.
Thank you
Daid 306
This is a bug with none ascii characters in filenames. It's been fixed for the next version.
Usually it's Russian characters, or characters with accents that cause this. It doesn't have to be in the filename, can also be in the path.
(It's actually a bug in the windows python version, and it only happens for windows, so it took me a bit of time to track down)
