Dim3nsioneer 558
Cura does the swap retraction itself (although I recommend to use the firmware retraction and volumetric flavor). The problem is that Cura (please tell me if I missed a change in code!) swaps the extruder every layer even if only one exdruder is needed on that layer; at least if you use the wipe&prime tower. Exchanging the extruder in the gcode is something TweakAtZ cannot do.
DidierKlein 729
With TweakAtZ you can change the nozzle temperatures at a layer height would that do the trick? Or would it also need to retract before changing the temperature?
