14.12-RC9 problem
tonycstech
Posted · 14.12-RC9 problem
Some version back, bridges would be filled at standard 45degres.
Now it fills everything else at 45 but bridges are filling in different angle.
I have a bridge 1 inch wide (left to right) 1/4 long (front to back)
New way of filling that bridge makes longer filling passes (almost left to right) VS 45degrees shorted one.
It causes allot of sagging.
Shorter passes would make it sag less.
Instead, it should have gone the other direction, filling it at 0degrees (front to back)
. Filling bridge going less possible distance would be better, but in this case it went the most distance causing too much sag and gaps in the initial overhang.
Is there some menu where i can change that or is this permanent bridge detection feature going to stay the same way forever ?
Bridgefill
    "some version back" is a bit unspecific.
    I did change the bridge detection algorithm a bit to be less broken (as bridge detection is a complex problem). But that was more then 6 months ago... so a few releases back...
    The idea is to span bridges by printing in the direction of the bridge. This works great, as it's pretty much the only way you can print in the air.
    You're example is incomplete, where are the "supported" areas, and where are the unsupported areas? Kinda bit of important information that is only in your head and not in the picture.
    https://www.youmagine.com/designs/dual-extrusion-mounting-aid
    If this object is printed as it is pictured, then my example picture would give you good idea of a bridge am having problem with. You have 4 bridges there if the model is printed as its pictured.
    Once cura makes up the perimeter at the top of any of those holes, then it would start filling it in at a strange angle instead of going 90degrees for shorter [wall to wall] distance.
    I still think that when you have a rectangular bridge, you gotta go 90degrees from wall to wall that are closest to each other, but in this new version its the other way around.
        • 56 replies
        • 29 replies
