Posted · Cannot generating gcode that works
Hi, I'm hoping someone can help me:
I am running the default replicatorg ultimaker version (0035) and can get a nice print when I use the pre-generated gcode for a 20mm box.
However if I try to generate my own gcode from the stl file it generates gcode that doesn't work (like it is for a different machine?) the bed doesn't set in the right position and it doesn't wait to heat up in the corner like it does with the pre-gen gcode.
I have it set to use skienforge35, I also get an unknown M code error for a M113. Is there a list of settings or something that I need to setup for the Ultimaker?
    • 2 weeks later...
