Same problem with extrusion here.
At last I've got my Ultimaker. Ukrainian customs robbed me for additional 500 euros. They call it tax but I think it's robbery.
Definately something is wrong with "Newcomer guide to your first 3D print". It doesn't work any more.
First strange thing I noticed - when you are using control panel in RepG you can't move head in to negative half axis.
Second strange thing - when you are printing something extrusion isn't happening at all. But extruder and hot end works fine - I've got nice test extrusion from control panel. I've noticed error message in log window when sent g-code to print - "Can't recognize M113". M113 means "Set Extruder PWM". There are two (at least - but may be more) M113 command in G-code - one in the begining (M113 S1 - set extruder to 100%), one in the end (M113 S0 - turn extruder off). I've tried all versions of Skeinforge and Slicer - same error in log and no extrision at all.
So I've tried Cure and miracle happened - nice print from first attempt (thanks spooner777 you saved me). I'm curious - what is wrong with RepG settings?
spooner777 0
Never mind. I changed to Cura and suddenly all my problems are solved! My third print is almost perfect!
