Posted · Sequential printing not working
I tried to slice the Make Magazine Shootout objects as a suite, selecting the "one at a time" option instead of "all at once". However, when I went to print it was still doing the objects all at once. Is this a known issue? Did I not use the feature correctly?
I couldn't find anything about it in the manual.
-Keith
    If the object height is taller than the granty height then it cannot do them one at a time otherwise the y axis rod could hit the already printed pieces.
    Granty height is located in the machine settings and is 48 mm for the UM2.
    I don't think that was it, but I'll double-check to verify. If it were the issue, it would be nice if there were some sort of cue to the user indicating that it wasn't going to print sequentially.
    -Keith
