Hello sir, thanks for the fast answer and sorry for my slow answer, i wasnt available last days....
ok, LH is layer height, but instead 0.1 mm and 0.15 mm i accidently wrote 1 and 1.5. shell thickness is always around 0.4 mm.
Retraction speed? huh, didnt even know that i can adjust it, it's just by me at the default retraction checkbox enabled. I found your options in the expert mode and they are the default too, 1.5 mm minimum, 0.02 min extrusion, combing enabled.
At 1st pic, i didnt configure anything, cura sliced it that way (but it had not a lot infill and the new layer didnt started every time at same point). Sorry if i wrote it wrong, some heights are starting on the other side of the model, not really inside.
In pic 2, again i dont know that i can even print a model with different layer heights, at same time. But, its the same layer height, i currently dont remember, but maybe i rised a bit the temperature, that could be the reason for the different heights.
I just noticed that the printer after retraction need some time to extrude the same amount like before retraction, you can see at pic 3 that the whole wall is underextruded. The house model is printed at 25 mm/s.
Sorry, but my english is not great
Thanks
yellowshark 152
Ok a couple of questions first. What is "LH"? Is it layer height? If so then that is at least part of your problem. I have never heard of anyone printing with1.0mm thickness let alone 1.5mm. I wonder if it is possible.
What shell thickness are you using?
What is your retraction speed and distance?
In your 1st pic you seem to be saying that at some heights the new layer is being started on an inner wall and at other heights it is starting on the outside wall. What did you configure to make that happen?
In pic 2 are you using the same layer height below and above the hole; they look different to me.
If you have two windows close to each other then in my experience the short run between the two windows can be quite difficult to get printed nicely. Best done at 20mm/s, definitely not 50mm/s.
I would suggest you try again with LH of 0.3mm, speed of 20mm/s and temp maybe 210 although I am assuming that is UM blue filament which I have not used.
