Marlin is setting the initial hot end temperature to 0. This is on a UMO with official HBK. Print was made from an SD card on an Ulticontroller. The firmware is the default from Cura 15.01-RC6.
M190 S65.000000 M109 T0 S192.000000 T0 ;Sliced at: Mon 05-01-2015 17:01:19 ;Basic settings: Layer height: 0.15 Walls: 1 Fill: 10 ;Print time: #P_TIME# ;Filament used: #F_AMNT#m #F_WGHT#g ;Filament cost: #F_COST# ;M190 S65 ;Uncomment to add your own bed temperature line ;M109 S192 ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F9000 ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F9000 ;Put printing message on LCD screen M117 Printing...
aviphysics 9
