Posted · Peek Insulator Clogged
My peek insulator is clogged. When attempting to remove it from the printer, the internal threaded metal portion began to attach from the Teflon portion (pic below).
How to do reinsert the metal porton back into the teflon portion without damaging the PEEK Insulator?
peek insulator
    • 2 weeks later...
    Thanks for the advice Frederik. Using an M6 nuts is a good idea for not stripping the brass thread, I will try that.
    I do not own a bench clamp. How did you secure the PEEK when you screwed in the brass thread?
