Ultimaker2 bowden clamps
gregwar
Posted · Ultimaker2 bowden clamps
Hello everyone
Trying to reduce the frictions of the bowden, I'm considering using a 4mm ID / 6mm OD bowden tube
It seems better when trying to move the filament manually inside it
However, the original clamps are too large for it (the stock bowden is like 6.35mm OD)
I've considered using alternative clamps, like Owen's, but it seems only adapted for Ultimaker1 (http://www.thingiverse.com/thing:11864).
I also could add Teflon band to enlarge the tube on the ends... any advice?
Is there good clamps that would adapt to slightly smallest tubes?
        • 4 replies
