Windows Error when Slicing
grayeyephoto
Posted · Windows Error when Slicing
Hi all,
I am getting an error in the Command Window when trying to slice in Cura (RC3 and RC4). I am using XP installed in Parallels on a Mac. This is the first time I have tried to slice anything on this machine.
My Steps:
1. Load STL
2. Edit Slicing Parameters
3. Slice Model
Cura Response:
1. Bar appears on the bottom and says "Starting..."
2. Command Window Updates with the following:
C:\Documents and Settings\Administrator\Desktop\modular_universal_joint.stl 0
Exception in thread Thread-2:
Traceback (most recent call last):
File "C:\Program Files\Cura_RC4\python\lib\threading.py", line 552, in __boots
trap_inner
self.run()
File "C:\Program Files\Cura_RC4\Cura\gui\sliceProgessPanel.py", line 127, in r
un
p = subprocess.Popen(self.cmdList[self.fileIdx], stdout=subprocess.PIPE, std
err=subprocess.STDOUT)
File "C:\Program Files\Cura_RC4\python\lib\subprocess.py", line 679, in __init
__
errread, errwrite)
File "C:\Program Files\Cura_RC4\python\lib\subprocess.py", line 893, in _execu
te_child
startupinfo)
WindowsError: [Error 14001] This application has failed to start because the app
lication configuration is incorrect. Reinstalling the application may fix this p
roblem
Any Ideas?
    • 1 month later...
    to confirm for others, on my first attempt with CURA (on a 'clean' vm of XP32), the Cura window just showed the status "Starting..."
    but (eventually) in the dos window I noticed several errors, with the last "WindowsError 14001"
    Downloading the 2008 redistributable and running that the allowed the GCode to build (quickly)
    Cheers
        • 26 replies
