Thats pretty weird. Did you contact support?
That is next on my list, was hoping someone might have seen it before. An knew a way round it. Or had an idea what is was, if I can sort it myself I will.
So I re-flashed the UM2 with cura, it installed happily I grabbed a different print one that I had done in the last 3 days and had worked and started it printing (I save all my GCode files to my harddrive then port them to SD card so have them all backed up) An it is also printing like the printer can't actually work out where the print head is!
Something has gone very wrong inside somewhere hasn't it.
It's dead.
I have emailed support, cradle won't return to the rear of the print bed.
Motor sounds like it's grinding internally.
The error message is return switch X or Y is broken.
I think they motor is dead and as it is not returning it is causing issues.
If I manually return it then switch it on it is fine but it can't seem to return itself.
SO I shall take a wild shot in the dark return switch fail due to motor fail which has caused it to lose track of where it is.
Hope support gets back to me today.
So I have got the printer going again, was a damaged wire leading into the motor, So sorted that printed the updated feeder, and got that all built and put on and was working fine, for that print, decided that I should print a second one just in case the first one goes wrong and I needed a back up and its not doing this thing where around 50% way through the print it unloads all the filament and carries on printing without any filament in it!?
fallen013 0
What the hell is up with my UM2!
I cleaned out the feeder section this morning, as it had a fair build up of dust in it.
I changed the filament over and then it came back with ERROR Contact Ultimake XY switch Broken!
I thought okay looks okay will just turn it off let it cool down and try again in an hour see what happens.
Seemed to be working fine then the jumping started again, it gnarled the filament in the feeder once more. It well you can see the photos.
I got a new SD Card, copied over a file I have printed many times before and it is well I don't know what it is doing!
Will add the photos in a minute. I just sat and watched it unwind all it's filament on its own while it carried on printing with nothing in the tube!
I am baffled and really starting to lose my mind over this has been working fine for about 2 weeks, didn't do anything too it had the SD card issue yeasterday when trying to put a new file in and now it's gone completely INSANE. I even did a factory reset between printing the white and the blue. In the images below and I am fairly sure it hadn't finished when it decided it had finished! I really really could do with some help here anyone.
I've only had the thing since a week before Christmas. Just started getting it to print really well and was happy with it and then this!
