cura 15.01 "fast print"
ultiarjan
Posted · cura 15.01 "fast print"
The "fast print" quick profile sets the shell thickness to 1mm, so you get a warning about it not being a multiple of the nozzle size. I assume this is not intended behaviour? A warning on a default setting is probably confusing for new users...
Do like the data copy, probably a helpfull tool for new users.
    The warning is that you're going to get less pretty results. Which isn't a huge issue for the fast print, so the warning is right, and I think the fast print isn't wrong as well.
