Posted · Plastic does not go to print
primero perdon por mi ingles de google traductor.
I ride my Ultimaker, everything moves along with the control panel operated by hand is extruder and goes well the PLA at 210 °, but when I send print I get little or no plastic, while the print engine of the extruder is not moves, what am I doing wrong?
    On the parameters of dimension says:
    Activate dimension, activate
    Absolute extrusion distance, activate
    Relative extrusion distance, off
    Extruder retraction spedd (mm/s) 0,0
    Filament diameter (mm) 2,8
    Filament packing densiti (ratio) 0,85
    Retraction distance (milimeters) 0,0
    Restart extra distance ( milimeters) 0,0
    What can i do?
    That should be right. Except for the packing density, that should be 1.00 for PLA.
    What software version are you using? And did you upgrade firmware or not?
