Extruder Motor
marble
Posted · Extruder Motor
May day may day
We lost one engine! :eek:
Hello everyone,
that would be a nice, reaally smoothed version of my help request as I have been struggling with this ultimaker for days. I am exhausted!
This Ultimaker 1st version works fine except for the extruder motor. There is no way it runs. I use Cura 15.01
What I did:
1. I unplugged the extruder motor connector and connected to the Z output. I began to pring and the motor spins in both directions. Motor OK
2. I swapped the drivers (the Z with the Extruder) to check them. Drivers OK
3. I tested the coil of the E motor by connecting two pins and then the other two. It seems to work too.
4. Did a standard ultimaker firmware upload. No differences.
5. I bought five brand new drivers. Same thing.
6. I checked resistors, capacitors, connection from the E driver to the arduino board.
Is there anyone who had the same problem?
Pleeease
    ho... cr... !!!
    I did not know that the extruder motor does not run when the temperature set is too low.... and I have worked all this time unloading the filament with just 35°C !!!!!! :O:O
    :rolleyes:
    thx anyway :)
        • 21 replies
