Posted · Spur gears in Inventor - help needed
Hi guys,
Does anybody here know how to design spur gears in Autodesk Inventor? Being an Inventor noob I'm kinda stuck at the spur gear designer window. I can't seem to get what I want from it. And that is 2 helical gears 47 and 9 teeth or something similar, 45,8 mm away from each other from center to center. Whatever I try to do, I get all sorts of Unit correction errors which I don't have a clue about.
Any help andor explanation would be much appreciated. :)
