Yep!! Youre absolutely right!
I Denmark (where i'm from), we use komma as a divider :roll:
Thank you for a very fast reply Daid
Best regards
Kasper
Best regards
Kasper
Same for where I'm from, but it's a common "bug" in software. However, I think the entry box should have turned red to indicate an problem...
I just checked to see if the box turnet red, but it dosn't. However the dialogue window comes up with an error, i just wasn't paying attation to that error as i was typing.
It would be great if the box turned red though.
What OS are you using? They might not turn red in MacOS (which has some less capabilities in the GUI toolkit)
I've also updated the code, so this problem won't happen in the next version
Im using windows 7 64bit.
Looking forward to the next version, it's allways exiting to see what news you come up with
By the way, i have a Nvidia graphics card in my machine, and the object view is still blank, but with the Cura 4 the dialogue box now works ;-)
The next version will be a bugfix release. So nothing new
I'm doing a "features" -> "bugfix" -> "features" release cycle. This forces me to concentrate on bugs first and features later.
Daid 301
Most likely you used a comma instead of a dot in the number of the "wall thickness", so 1.2 should work, 1,2 will give this error.
