I tried ABS. It shrinks the pins little to 5.6 (instead 5.8). But still impossible for me.
The Screwless Cube will perhaps better work. Yes. It's pins do have a long good slit that looks springy
I've actually printed this and it currently works right now. I had to use pliers to get the pins in.
To be honest the regular "screwless heart gears" are much better.
Thanks
I got the pins with a hammer and ABS.
I do have a additional question. I have problems with the center. It broken me in to tries into 2 Parts.
With PLV it looks like, the single layers are not glue together. With 100% infill perhaps no problem. But with 60% even the walls are not sticking very well.
Is this only a problem of temperature?
Can I generally say, that with higher temp, the layers will stick better together?
Or should I print faster that the lower layer is still "warm"?
Thanks
PS: With ABS there was a split in a layer. Perhaps only bad luck. :evil: But ABS looks generally more fragile.
Yep, generally if your layers aren't sticking together you need higher temperature.
Daid 306
Actually, ABS is a bit more springy, that's why most of these "clamp to fit" parts are quite hard.
Have you tried the screwless cube gears? those work for me with PLA.
