Any plans to fix the layer view bug when using a Plugin?
jweaver
Posted · Any plans to fix the layer view bug when using a Plugin?
There has been a problem with CURA for a while and I just wonder if its something you could consider fixing?
When using a plugin such as "pauseAtZ", the layer where the pause happens only shows the tool path and not the extrusion.
cura plugin layer
I believe this is just a GUI bug, but it makes it almost impossible to tweak the plugin to hit exactly the right layer and this is causing me a lot of wasted time.
Jon
        • 21 replies
