In stead of messing with the code of Marlin, I started to swap out resistors 4.7k ohm was what I have been using this whole time. I tried 10k with no better results.
With each resistor I recompiled the look up table with the Python script from Rep Rap
22k ohm works ! It starts off around ~ -20 only 2 less then the last value in the table {1008, -22}
47k ohm works as well but it starts around -44
Testing the 22k ohm resistor, Using my fingers to heat up the resistor It only returns a result of ~9c which means I should be dead.
But I don't care, its working with out messing with any Marlin Code and no need to pre-heat the resistor.
I'll be testing the results of the 22k ohm resistor at 60c, 70c, 80c, 90c, 100c with my toaster oven.
( I have one of reflow solder hacks that controls the oven's temp with an external micro controller)
Thanks for everyone listening and reading to my troubles,
Brian
Daid 301
You'll have to compile the firmware with a heated bed enabled or 2nd extruder enabled. But then they work.
