Manual Enable Heater 2 and Hot Bed
flyguy
Posted · Manual Enable Heater 2 and Hot Bed
Hello,
How would I enable the other heater transistors on the Ultimaker shield ?
Would I just Edit the Pins.h file to make sure that the right pins are defined ?
#define HEATER_BED_PIN 3
#define HEATER_1_PIN 4
(I know these pins are different then default)
#if MOTHERBOARD == 7
#define KNOWN_BOARD
* Ultimaker pin assignment
#ifndef __AVR_ATmega1280__
#ifndef __AVR_ATmega2560__
#error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
#endif
#endif
#define TEMP_BED_PIN 10
#define HEATER_0_PIN 2
#define TEMP_0_PIN 8
#define TEMP_1_PIN 9
Is there anything else that needs to be modified to enable the Heating transistors ?
    Ok I uploaded some basic code to the Arduino 2560, AND the 2 pins that I thought were dead are not.
    So I am missing something to enable the Heated bed, and the Heater 2 transistors. Anyone have an idea where I would go to enable these in the Marlin firmware.
    const int lowestPin = 3;
    const int highestPin = 4;
    void setup() {
    // set pins 2 through 13 as outputs:
    for (int thisPin =lowestPin; thisPin <= highestPin; thisPin++) {
    pinMode(thisPin, OUTPUT);
    void loop() {
    // iterate over the pins:
    // fade the LED on thisPin from off to brightest:
    for (int brightness = 0; brightness < 255; brightness++) {
    analogWrite(thisPin, brightness);
    delay(2);
    // fade the LED on thisPin from brithstest to off:
    for (int brightness = 255; brightness >= 0; brightness--) {
    delay(2);
    // pause between LEDs:
    delay(100);
    http://daid.eu/~daid/marlin_build/
    This page has no options to enable the heater or the heated bed. It only allows you specify the sensor, not the heater its self. I thought I had dead pins on my Arduino so I ordered a new one. But it turns out that its a software issue.
    In the Configuration.h of the marlin firmware I have it already set
    #define TEMP_SENSOR_0 -1
    #define TEMP_SENSOR_1 6
    #define TEMP_SENSOR_2 0
    #define TEMP_SENSOR_BED 6
    But the hot_bed and heater 1 still do not work. only heater0 works. (the hot end heater)
    Help! Anyone having issues using the Heated bed MOSFET on the Ultimaker Shield ?
    Here is my setup for Marlin:
    http://daid.eu/~daid/marlin_build ... stepsE=800
    I can see that the thermistor is working in the PrintRun. I can connect to the machine and and use a heat gun on the themistor to get a proper temperature reading.
    Next step is setting the Bed Temp to 60
    Here is some of the read out with the Monitor Print box checked.
    ok T:35.7 /0.0 B:3.0 /3.0 @:0
    ok T:35.8 /0.0 B:3.0 /3.0 @:0
    ok T:35.2 /0.0 B:66.6 /3.0 @:0 (Applying Heat gun)
    ok T:35.2 /0.0 B:78.8 /3.0 @:0
    ok T:35.1 /0.0 B:95.2 /3.0 @:0
    ok T:35.2 /0.0 B:73.0 /3.0 @:0
    ok T:35.2 /0.0 B:58.1 /3.0 @:0
    Setting bed temperature to 60.0 degrees Celsius.
    ok T:35.5 /0.0 B:46.0 /60.0 @:0 (I Expect the red LED on the MOSFET to turn on here But it does not)
    ok T:35.6 /0.0 B:27.2 /60.0 @:0
    ok T:35.7 /0.0 B:3.0 /60.0 @:0
    ok T:35.6 /0.0 B:3.0 /60.0 @:0
    I do know that, the pin on the Arduino is good as a I wrote a basic Pin High/Low program and watched the LED turn on and off.
    Any help thoughts or suggestions would be greatly appreciated.
    In stead of messing with the code of Marlin, I started to swap out resistors 4.7k ohm was what I have been using this whole time. I tried 10k with no better results.
    With each resistor I recompiled the look up table with the Python script from Rep Rap
    22k ohm works ! It starts off around ~ -20 only 2 less then the last value in the table {1008, -22}
    47k ohm works as well but it starts around -44
    Testing the 22k ohm resistor, Using my fingers to heat up the resistor It only returns a result of ~9c which means I should be dead.
    But I don't care, its working with out messing with any Marlin Code and no need to pre-heat the resistor.
    I'll be testing the results of the 22k ohm resistor at 60c, 70c, 80c, 90c, 100c with my toaster oven.
    ( I have one of reflow solder hacks that controls the oven's temp with an external micro controller)
    Thanks for everyone listening and reading to my troubles,
    Brian
