If you print with USB, you will run into buffering problems, causing stutter. But if you print from SD card with an UltiController, you will do fine.
It does take a insane amount of time to slice something that large. You can try slicing with RepG or Cura without having an UltiMaker. If it slices, it should print with the UltiController.
Daid 306
