A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Daid 304
Most likely your older macbook does not support 64bit applications. The bundled pypy is 64bit.
If you remove the pypy directory, it will stop using pypy for slicing, which will make it about 4 times as slow, but it will work.
