Your only way to reliably check for a plug is to take apart the hot end. I've had ones where manual extrusion still worked, but whilst printing the flow is just too small. You only have to undo e four large screws and lower the peek away from the tube, not take the whole hot end apart. Read the wiki page before you begin. Once you have it back together put a small mark on your Bowden just where it passes through the top piece of wood of the hot end, then you can later monitor to see if it's slipped and thus almost certainly has a plug.
Thanks a lot. Indeed I had a beginning plug and cleaned the hot tube as suggested by only undoing the four large screws. I did the mark. Hopefully there will be no plug soon. It prints fine again.
Cheers, greengecko
jcosmo 5
