It sounds like something is misaligned.Either your bowden tube is misaligned and the filament is actually feeding to the side of the teflon tube or there is a significant lip on your Teflon tube that's causing excess friction.
When feeding the filament watch carefully that the filament passes through the teflon part (the white thing that touches the bowden)
Ensure that the bowden is slightly in the teflon piece. Note where the filament stops feeding and clicking begins. If it's a few seconds after the teflon tube, it's most likely the Teflon piece itself. If it is at the end of the bowden tube it's probably misaligned. It doesn't sound like it's making it to the heated nozzle part at all.
Thanks for the reply, I was wondering if it was the PTFE piece, since I'm well over 500h now on the original.
The printer has been running pretty much 24/7 for a couple of weeks and used every other day before that since November.
Everything has been perfect so far, but I decided to experiment by running a print at 100mm/s speed. I usually keep to around 40/50 but I thought I'd experiment.
The print quality wasn't great so I aborted the print after about 40 minutes, then tried printing again at a slower speed (back to 50 again) but that's when I noticed that filament wasn't coming out anymore.
So I'm thinking... disassemble the print head and check that everything is in order?
valcrow 144
