Posted (edited) · Issue With Infill/Bridging
Print: http://www.thingiverse.com/thing:704409
Here's the print, I think it is definitely evident not only on the "bridging" portion but on the layer that all of it sits, on, holes ETC. (Note this was printed at 100mm/sec, but i think it is definitely doable)
Settings:
*Extruder temp: 215C*
*Bed Temp: 50C*
*Ultimaker Silver PLA*
Quality:
Layer Height: 0.1mm
Shell: 0.8mm
Retraction: Enabled
Fill:
Bottom/Top Thickness: 0.6mm
Fill: 33%
Speed
Print speed: 100mm/s
Support:
None
Machine:
Nozzle: 0.4mm
Quality
Initial layer: 0.3mm
Initial layer line width: 100%
Cutoff object bottom: 0mm
Dual extrusion overlap: 0.15mm
Speed:
Travel speed: 150mm/s
Bottom layer speed: 20mm/s
Infill speed: 100mm/s
Top/bottom speed: 0mm/s (100mm/s)
Outer shell speed: 75mm/s
Inner shell speed: 0mm/s (100mm/s)
Cool:
Minimal layer time: 5 sec
Fans: Enabled 100%
The results:
Sorry for the upside down image. Thanks Apple.
