But now I encountered my first problem with Cura that I cannot solve on my own. I have designed a thin wall grid (0.4mm) and wanted to slice it with cura. Maybe someone out there has an idea, what I am doing wrong.
You are not doing anything wrong, cura does.
change your nozzle size in Cura to 0.35mm, and see if that helps
Daid 301
Simply put, it's the thin wall problem. Thin objects are currently very hard to slice with the implementation found in Cura. You could try making the walls 0.5mm in width to see if that helps.
