It's too thin. I had to go down to a 0.18mm nozzle to get it to all show up. You can do that if you want - tell Cura you want 0.18mm shell and it will slice and it will work but it will be a bit underextruded because the actual nozzle is 0.4mm (not .18mm). You can then tell it to use flow of 200% and you will get an okay print. But ideally you should fix the cad model so the walls are at least 0.8mm thick.
gr5 2,229
gr5 2,229
By the way alternatively you could buy a .25mm nozzle - this will print .18mm shell just fine.
Roth 0
You're right! Thank you for the quick response!
