Remove the filament and cut the tip to a point. It often gets hung up inside the print head where the bowden tube meets the white teflon part. Also inspect this visually to make sure the bowden is securely sitting inside the white teflon part.
You can try feeding manually. For example, power cycle the printer, go to ADVANCED and turn on only the print head to 180C. When temp gets there push and pull on the filament a few times - it should go through the bowden no problem (it's possible there's something inside the bowden binding the filament - that happened to me recently). Push nice and hard - about enough to lift the printer up off the table - that should be enough to get a small amount of filament through the nozzle. If that's not working - it's obviously not the feeder.
gr5 2,210
