Um - "never use default settings"??
I don't know what they are but I believe it does infill at a faster speed. You are probably already printing close to the limit for your given layer height and temperature and the infill speed is probably much faster. I think defaults are 50mm for shell and 80mm for infill.
Here are top recommended speeds for .2mm layers (twice as fast for .1mm layers):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion.
Thanks for the reply. I didn't see this till just now. i will try those out and let you know how I go. It's weird as this problem has never popped up until just now but thanks for the input.
gr5 2,210
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
Edited by GuestLink to post
