You are right on @DidierKlein. After experimenting around with different heights for the metal coupler, i decided to swap out the Ollsson Block for my new OEM heater block. I couldn't get the block to not touch the bottom of the fan bracket. I'll wait until labern finalizes his model or metal version. I don't print with exotic material or plan to anytime soon so I can wait. Thank you DidieKlein for your input on this and Super thanks to @gr5 for recommending me to play with different temperatures for printing PLA. AFter putting on the new OEM heater block, telflon coupler and so on, I test printed a ring with temp set at 230 C and printing at 50 mm/sec, it gave me the best print to date since owning my UM2. It came out flawlessly and not even one string of material or hole can be found. The top layer is just as smooth as the bottom layer which I never could get. I am really liking this printer now
It could happen because the fan shroud is touching the heat block, when the fans start to blow a lot the temperature will drop, and the heater error will pop up.
You can increase the height of the block by tightening the heater steel coupler (or insulator). Heat up and turn it a bit with a screwdriver in one of the holes.
Beware that this steel coupler can break easily, heating up is mandatory. It's safer also to do this without the pressure of the spring.
Or print another fan shroud that is best suited for the olsson block to add more space between them.
Ps: if you tighten the steel coupler don't forget to re-level your bed.
Pps: Distance between steel coupler and teflon should be around 1mm, if you have an I2K insulator thighten at maximum to add more pressure.
You can test my answer by printing with no fans or increasing manually and checking the temperature
donnyfl 1
