The whole machine just friezes, I can see the Arduino blinking underneath but all motos stopped. Also the print progress indicators in RepG get stuck. The USB cable is fine, it is the same one I used since the beginning with two magnetic ends and the Mac never goes to sleep. So I suspect the Arduino stopping due to peaks in the power supply like you are suggesting. It happened since we moved to a new place therefore I am quite certain. I will try the power surge power strip.
Printrun looks great but seems to be lacking one feature I often use in RepG, the travel rate multiplier.
joergen 2
What exactly is seizing up? here is a list of things that could happen:
1. Arduino: seemingly just stops doing anything, midprint. Cause: multiple, but most likely spikes from the power supply, use a power surge power strip, to separate dirty AC spikes from reaching the power brick, and/or stop using your vacuum cleaner while printing (especially in the US, where appliances and AC power are just plain crap)
2. Mac: make sure you use a good USB cable, if it wiggles, and/or has questionable contacts, use a fresh one
3. set your mac to never sleep
4. use print run to send your gcode to the printer: http://koti.kapsi.fi/%7Ekliment/printrun/
