"3d printing" makes people think it's as simple as hitting the "print" button for a 2d printer but it's not. It's more like owning a CNC milling machine. There's a lot to learn. So you might want to just order stuff on 3dhubs.com at first.
I recommend you use 3dhubs.com also to compare models of printers as they have rated hundreds of printers using thousands of reviewers.
The one feature I recommend is "open source". I didn't realize how important that is until after I got my printer. Having a printer where you violate the warranty if you modify it or having a printer where you are forced to buy the manufacturers filament is very bad thing.
I was think of getting a XYZ Da Vinci 1.0 printer i dont know yet. I do know how to use all cad softwares.
thank for the reply
gr5 2,210
