requestRotate about axis
phut
Posted · requestRotate about axis
One thing I think Cura is really missing in its visualisation is the ability to simply rotate an item on the axes for a new print orientation (aside from the Z axis).
I would certainly use this function more than the swap axes commands, as I have found that it is often error prone to swap axes to change the printing orientations (due to reversal of the item). For example if I had an 'upside down' STL or just one that I wanted to print the other way up, an asymmetrical model is going to come out incorrectly if you only hit the Z mirror button.
    this is the only reason why I keep a copy of repG around: it's easy to rotate STLs that are off
        • 56 replies
        • 29 replies
