Or, to avoid stringing, print two at the same time, or print a wipe tower as well. @DidierKlein is correct about the chimney; the plastic simply stays liquid in such a small area, and gets shoved around and messy. If you watch the chimney printing (assuming you are printing one boat by itself) and you will see how the nozzle moves the plastic around almost like dough.
Avoid using coll lift-off as the nozzle will dribble while waiting to print the next layer, so instead print a wipe tower. This will get around the whole problem.
DidierKlein 730
To reduce stringing, print colder and increase travel speed on my UM2 i go up to 250mm/s
I would also increase layer height to 0.1mm, the problem you had on the chimney probably comes from the small layer height. The previous layers don't have enough time to cool so they melt when the next layers are printed.
