Are you sure the Z axis is involved? It looks like your X and Y axes aren't perpendicular. I can't tell from the pictures if the Z axis has anything to do with it. But assume X and Y aren't perpendicular - it can only be caused by the rods not being perpendicular. Either the two thinner rods or the 4 longer rods.
DHL and other shippers seem to do a horrible job and seem to let elephants sit on the boxes as part of the shipping process such that an originaly square Ultimaker arrives as a parallelogram.
I would measure these axis carefuly with a carpenters tool or you can measure the corner-to-corner diagonals at the top to see if everything is square (see if diagonal distances are equal). Using a small carpenters "square" is easier. The problem should be solely in the gantry area. In theory you can loosen all the edge screws, clamp the box a bit *past* square in the other direction and then tighten everythin up again.
Alternatively, if you are lucky, it's simply either the X or Y blocks aren't lined up and one or both of the thinner rods that go through the head aren't square. This is much easier to fix - just loosen the pulleys for the 4 long belts - one pulley per belt I think should do it - so only 4 pulleys need to be loosened. Push things back to square and then tighten the hell out of those pulleys - the set screws in the pulleys need to be so tight you are twisting the hex tool (2mm hex wrench needed).
gr5 2,229
