The Gcode is clean, i am sure of that because one french user tested it, and it worked.
I don't have it on me now, i'll post it there this evening.
Maybe that's your problem?
Also. Just a weird idea. Maybe the z steps are changed and it's moving more phisically than it should? I would reset settings on the panel and update the firmware.
Yeah this sounds very close (if not exactly the same). I'm in contact with Makershop, is that the right way to get another panel if it is the real cause of my issue? Or should i contact directly Ultimaker staff?
About the settings and firmware, i always create a new machine and update firmware before every test.
I suppose that (I'm really not sure) you could disconnect the panel and print by usb. Usb printing can give problems since usb can have power changes, but for the purpose of the test you could send the gcode by cura usb with the panel disconnected and see if it makes the same error or it doesn't.
When you say "panel", are we speaking about the same thing?
Because without this, i can't even connect the printer with USB.
Edited by GuestHeh no. That's the main board indeed.
I thought when I did read that other post that the op fixed it by changing the ulticontroller. I did understand it wrong I suppose
To me, the ulticontroller is a receptor concerning the display and an emettor concerning the button, but in no matter a processor for taking decision and saving datas. But please do tell me if i'm wrong!
neotko 1,415
Can you post the first 50 lines of that gcode just to remove that from the possibilities of what causes that?
