Ok, Thank you.
I have switched to Windows and i installed Cura to see weather the check runs there.
But i still have a Problem. I failed again. After temperature check i should press X End in front left corner. I moved the extruder bye hand to left but nothing happens.
Daid 303
The firmware update is good (the supplied firmware is quite new but very stable)
On Mac the wizard fails for some reason, not sure why yet. I've had more reports. Just skip the wizard for now.
