There are a few issues that can cause things like this.
How Many hours has your printer printed? the PTFE coupler can deform and not allow the filament to flow properly.
It can be a nozzle clog that needs a few atomic pulls to clear or you may need to push a fine wire up the center of the nozzle when its hot and rub around the inside edge.
Could be the feeder tension isn't enough and is slipping.
and lots of other things that I cant remember right now.
You can try removing the bowden tube from the top of the hot end and pushing some filament through by hand. see if there is much restriction there. if ok, look at how deep the imprint from the feeder is on the filament. if there are light marks the you can increase the feeder tension.
Thanks! I reassembled the nozzle again--this time making sure that the PTFE coupler was within 1mm to the isolator Nut and I'm back up and printing
1
Labern 775
