I'm finding I have to change width over thickness and increased cooling time for it to work with the lower layer height.
Not sure why you'd need to change the cooling time but it doesn't surprise me too much..
For the w/t part, it makes perfect sense.. "Thickness" is sf-speak for layer height and "over" is math-speak for divided-by so "width over thickness" is the width of threads divided by the layer height.
If you start with a layer height of 0.20mm with a w/t of, say, 2.0, you have threads that are 0.4mm wide. If you just change the layer height to 0.10mm without changing w/t, SF ends up mapping things out so you have a thread width of 0.2mm wide - that's hard to get right with a 0.4mm nozzle!
There are SF wrappers (like Daid says) that will do this math for you but what I do is just find a profile that I like the quality on and remember the thread width on that - between 0.40mm and 0.50mm will work nicely on an Ultimaker, though the actual usable range is probably around 0.35mm to 0.75mm or so. Once you have that, pick whatever layer height you want then divide the desired thread width by the layer height and plug that into the w/t.
Example: say you like 0.50mm thread widths..
- for layer height = 0.25mm, w/t = 0.50 / 0.25 or 2.0
- for layer height = 0.20mm, w/t = 0.50 / 0.20 or 2.5
- for layer height = 0.10mm, w/t = 0.50 / 0.10 or 5.0
Just remember to change both w/t values.. There's perimeter w/t in Carve and infill w/t in Fill.
Not that I've typed all that in, I wonder if I understand the question.. Does this help?
Daid 303
First, dump the "W/T ratio", like I did for Skeinforge_PyPy: viewtopic.php?f=8&t=153
That saves you 1 trouble. I took my 0.2mm profile, adjusted the layers to 0.1mm, and printed. Same temperature, same everything. And it came out great.
I've never seen an object get worse from more cooling...
