Yes the feeder shouldn't skip back unless there is to much pressure built up in the nozzle or a snag of the filament.
Sometimes the printers need some adjusting even from new. They just print a test sample and ship it off. as long as you have good impression like shown Here
Is the design your own or Someone else's. You can check in with cura 15.04 under xray view to see if there are problems in the model.
I'm not to familiar with the material you are using. It could be good to try the UM stuff, even if it for something else. Different brands can print very differently, even different colors.
How much of the ABS have you used?
Have you done atomic pulls?
You can try loosing off the 4 thumb screws on top of the head a bit. not so its loose but just holding.
A lot of people just put the roll on the floor on its side and let it uncoil on its own.
Labern 772
increasing the feeder current can make the motor hot. As the motor gets hot it can heat up the drive wheel which can deform the filament.
What size/tolerance is the filament?
It sounds like your issue is worse then normal, have you tried printing with the grey UM filament?
A lot of people print This and This to help resolve some of these issues.
rotorhead 1
The filament is sold as 3mm but is actually 2.91mm. I have set the Ultimaker to this although I have tried it on the default 2.85mm and had the same problem. I have not tried printing the same part with the silver OEM material as it's quite a large piece. Perhaps I should?
Yes I spotted that feeder and was thinking I should try it. I like the idea of the low friction spoolholder too. Both seem like a good idea but like you say, my problem seems worse than normal. I see what you mean about increasing current to the feeder.
Presumably the feeder motor should ideally never skip back when things are working properly?
and presumably since the UM2 comes shipped with the tension indicator right at the top, that's where is should really be?
