Vid - Ultimaker shroud to help with lifting corners
upsw
Posted · Vid - Ultimaker shroud to help with lifting corners
Howdy
I've got a lot of help out of the forums and internet in how to fine tune print settings. I thought I'd do a short video of my current set up to help others hopefully
Hope someone finds it of use
N
    • 1 month later...
    I ended up just running with the sides - no top. Found this a good compromise. Running with the top on made it get too warm. You could see the guide rails getting heat coloring from continual movement.
    I was thinking of insulating around + underneath the heated bed. Surely it must loose a lot of heat from underneath. (Waste)
