Tweak At Z reset at height
patrick181
Posted · Tweak At Z reset at height
UM2
Cura 15.04
TweakatZ 4.0.2
I have multiple prints of the same part that need fans on at 9mm Z. Problem I'm having is that TweakatZ does not reset at the beginning of the next print/part and leaves the fans on for the remaining parts. Cura is set for Print One At a Time. Any ideas how to accomplish this?
TweakatZ documentation indicates a "Reset previous values when printing one-at-a-time" if this the same thing?
    Posted (edited) · Tweak At Z reset at height
    Congrats, you pointed me to a bug. Reset on an UM2 is not properly done if the setting is visible within the gcode (i.e. a machine setting). However, this should exactly lead to not changing any behavior which would lead to Cura's default which is an M107 at the start of the layer. I guess I will have to look at this in a quiet minute...
    Would be nice if you could submit an issue on Github.
    Thxs.
    @patrick181: Any news yet?
