How to replace the heater cartridge on my UM2
joshh
Posted (edited) · How to replace the heater cartridge on my UM2
Hi all. My Ultimaker has jammed up plenty of times during its life. All of which were fixable with some work. This one however I will now need to replace my hot end as well as the wiring. I already have all the new parts I require but I am here today asking about what the best way to do this would be. Specifically how I should go about replacing the heater cartridge. The wires seem to be clamped down to the Arduino board, but when I tried to remove the board I found that I would have to take the side panel off that connects to the motor and I didn't want to risk messing something in there up so I haven't touch that. Not to mention the thousands of screws I would have to undo to get there. This jam is especially bad because it is Ultimaker ABS instead of PLA. I understand ABS isn't highly recommended for the Ultimaker but my application for the machine required a use of stronger filament. Never the less, I tried to melt the abs with a lighter but it only started to burn. I can't seem to get it to melt. That's why the head looks so burned...that's because it is. But now that I have the parts I am ready to make the swap. All I need now is the know how of how the change to heater wires.
Any and all input is appreciated :)
- Josh
    Posted · How to replace the heater cartridge on my UM2
    I moved your topic in another subforum ;)
    I have a step by step guide for the temp sensor, you can find it here.
    Also with the help of the assembly manual you should be able to change it :)
    Maybe try with a heat gun as advised by nicolux? The head doesn't heat up anymore?
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 11 replies
