You could buy a umo 2.1.1 chinese version (99€) and reuse almost everything (except you would need the pt100). Even the heater works. But this kind of upgrade would work better if you have the umo bed upgrade kit because the power supply it's the same of umo+/um2. Ofc the original board from ultimaker cost 250€+ and it's much more reliable. I got an umo (not plus) box and to adapt it to the 2.1.1 board it's just as easy as making a few holes and cutting a bit the wood frame (not cute but works). If anyone goes this route on chinese board check that they put the power button and that they have the give you the safety pins. Mine didn't and it was a mess (also the connectors for pt100 and fan/led where upside down...). But they are cheapo
Edited by Guest@ataraxis I was looking for other stuff and I saw this, I don't know much about this stuff but seems like it might work (the e3d little amplifier)
http://wiki.e3d-online.com/wiki/E3D_PT100_Amplifier_Documentation
1
neotko 1,417
I would drop an email to e3d about their little amplifier for pt100. I think it might/could work?
http://e3d-online.com/Electrical/Electronics-Boards/PT100-Amplifier-Board
Drop them an email, they answer really fast and they are quite friendly.
ataraxis 51
Looks good, Thanks! Maybe I should change the whole hotend some day... ;D
Edited by GuestLink to post
