Ok
that sounds encuraging.
now how do i use it at the right time?
Do i need to guess where the gcode meets the layer i want to change the color?
and input a M0 command.
How do i resume?
Im planning to do all the printing with the ulticontroller.
Thanks for your reply.
Daid 303
I've implemented M0/M1 for this in the firmware if you use an LCD panel. See:
http://www.thingiverse.com/thing:23589# ... -655077513
The printing interface in Cura 12.08 also Pauses when it sees a M0 or M1. So it also works from there, but it won't work from PrintRun, as it will send the M0 or M1 to the printer, and the printer will wait for an LCD button push then.
The plan is to add better support for this in Cura. But I haven't done that yet.
