Posted · Heater Error
Hi I Have UM2 Extended.
I just replaced my hot end assembly and now I am getting heater error. Not sure why this is happening as the heater was working fine before.
Is it that I damaged it? Or some other issue?
Temperature sensor seems to be working fine.
    Thanks for you quick reply.
    I checked the assembly again, no part is in contact with hot end or nozzle. I also tried heating when hot end was separate from the carriage.
    Temperature does not increase even slightest bit.
    I have ordered for another heater but I am worried if i am on the right track.
