Simplify3D hidden / undocumented Placeholders for post-processing scripts
neotko
Posted (edited) · Simplify3D hidden / undocumented Placeholders for post-processing scripts
I posted this on S3D forum, but seems that the moderators don't want this posted (It's been 2 weeks) so, well.
Just in case someone it's interesting on doing something more advanced on the scripts tool change or just any area in general that allows scripts in Advanced, there are quite a bunch of placeholders that work and that ain't documented anywhere.
[toolchange_retract_distance]
[toolchange_prime_distance]
[retract_distance]
[prime_distance]
[retract_speed]
[travel_speed]
[current_position_x]
[current_position_y]
[current_position_z]
[next_position_x]
[next_position_y]
[next_position_z]
[previous_direction_x]
[previous_direction_y]
[previous_direction_z]
[next_direction_x]
[next_direction_y]
[next_direction_z]
[average_direction_x]
[average_direction_y]
[average_direction_z]
{MATH } <-- This one I have not been able to make it work, probably it's not active atm and might work on latter versions.
I got all the placeholders editing in hex the app file.
Example of stuff that you can do with this:
G0 Z100 ; Move Z to another position
G0 [currect_position_z] ; Restore correct position
(this adding more stuff in the middle it's how I'm doing my hotend wiper.
You could also send info to the ulticontroller on Layer change script area:
M117 [current_position_z] etc etc etc
The most interesting for me it's the MATH, but I had zero success in making it work.
I posted this on S3D forum https://forum.simplify3d.com/viewtopic.php?f=8&t=3550 it's hidden, because S3D forum it's worse than... Crap? :)
  • Like 4
Posted · Simplify3D hidden / undocumented Placeholders for post-processing scripts
Other posible placeholders, that I haven't test:
[fan_speed_percentage][fan_speed_pwm][bed0_temperature][bed1_temperature][bed2_temperature][bed3_temperature][bed4_temperature][bed5_temperature]#[extruder0_temperature][extruder1_temperature][extruder2_temperature]
    • 11 months later...
    For scripting, in addition to NEWTOOL you can just use TOOL
    ie
    {IF TOOL = 1}G1 ASDF
    {IF TOOL=0}G1 not ASDF
    Found this helpful for custom mixing extruder profile.
    • 1 year later...
    Hello Any news on this topic?
    I mean, does S3D 4.0 have these same placeholders?
    Is there some way to get the temperature at current layer to make a tool change script?
    Thanks
    I found this in 4.0 app
    [retract_speed]
    [travel_speed]
    [next_position_x]
    [next_position_y]
    [next_position_z]
    [next_direction_x]
    [next_direction_y]
    [next_direction_z]
    [old_tool]
    [new_tool]
    [toolchange_retract_speed]
    [extruder3_temperature]
    [extruder4_temperature]
    [extruder5_temperature]
    [bed0_temperature]
    [bed1_temperature]
    [bed2_temperature]
    [bed3_temperature]
    [bed4_temperature]
    [bed5_temperature]
    [total_filament_used]
    [extruder0_filament_used]
    [extruder1_filament_used]
    [extruder2_filament_used]
    [extruder3_filament_used]
    [extruder4_filament_used]
    [extruder5_filament_used]
    [total_filament_weight]
    [extruder0_filament_weight]
    [extruder3_filament_weight]
    [extruder4_filament_weight]
    [extruder5_filament_weight]
    [total_filament_cost]
    [extruder0_filament_cost]
    [extruder1_filament_cost]
    [extruder2_filament_cost]
    [extruder3_filament_cost]
    [extruder4_filament_cost]
    [extruder5_filament_cost]
    [total_print_time_sec]
    [build_size_x]
    [build_size_y]
    [build_size_z]
    [total_layer_count]
    [progress]
    [current_Z_position]
    [current_layer]
    Bel lavoro Pieri70! These extruder[K]_filament_used are interesting, but in my opinion the most interesting are those with the = => =< and other simbols after the placeholders.
    @neotko posted some screenshots some time ago, I tried to use some of those but without results, without a serious documentation it is quite hard to improve the profiles and the prints.
    I recently discovered another thing by trial and error...you can do logic operations with "&&" and also inequalities work. For example:
    {IF NEWTOOL=1 && [current_layer] = 1}  Gxxxx whatever Gcode you want, will be inserted only if both conditions are met.  I didn't try || as a logical "OR" operator, but I would guess if && works then || also works.   Also, inequalities do work, for example:
    {IF NEWTOOL=1 &&  [current_layer] < 10}  Gxxxx
    Also, I tried several ways of referencing the Primary Layer Height, and struck out on all of them.  I don't know if that exists as a variable, but I can tell you these are NOT valid variables: [primary_layer_height];  [layer_height]; [first_layer_height]; [prime_layer_height]; [layer_height_z]; [delta_z] (OK clearly I was getting desperate here).
    • Thanks 1
    I discovered something else very bizarre.   MERELY REFERENCING A VARIABLE NAME CAN ALTER THE GCODE.   In other words, you might think that if your toolchange_prime_distance is a certain number, then you can type that number, or type [toolchange_prime_distance], and either way, that number will get inserted into the Gcode.   And that generally works for that immediate variable reference.  BUT ...it can cause the slicer SW to behave differently later.  In other words, it "remembers"  the fact that it resolved the variable name, and that memory might cause it to do something else.
    In my particular case, referencing [toolchange_prime_distance] caused the software to believe that it had done a prime movement.  If I merely put G1 E12 for example, this was not "remembered" as a prime movement.  But if I put equivalently G1 E[toolchange_prime_distance}, then the software counted this as a prime movement, and behaved differently later (in my case, deleting a different, later prime movement).
    The whole sad story is posted here:
    https://forum.simplify3d.com/viewtopic.php?f=9&t=12966&p=49691#p49691
    So - beware variable names.  They are useful, but you have to verify they aren't messing up anything.  The only way I know to do that is case-by-case, generate Gcode with and without the variable name and compare them.
