I am having trouble with the pause at height / tweak at height plug in. It is a case where I do not want to use it but it still pauses at the default of 5mm even when I "x" out the plug in to disable. I tried to set the height for these settings at 99.mm. (because I do not print that high) and I figured it would take care of the problem. But this seems to cause other issues with the print stopping. I would like to know how to disable it completely or work around it.
Dim3nsioneer 557
I guess you're talking about Cura 15.09.8x. Actually, no postprocessing script should be activated by default. However, if you go to Extensions -> Post Processing -> Modify Gcode you get the dialog of the post processing plugin. If you have any postproc scripts activated (in the right column) deactivate them by clicking the 'x'.
Maybe you give us some more details about which postproc script you actually mean, 'Pause at height' or 'TweakAtZ'? Please also confirm the Cura version you're referring to. Thanks.
